Connector inner dim
If I had to make a guess... it might be trying to use the wrong stylus in your star system. Open the circle path strategy and make sure you have the correct # selected.
A screenshot of the circle strategy would be helpful.
In order to test Perry's suggestion, manually select the stylus that is used in the first circle strategy, set the coordinate display in the traffic light window to base alignment and position the downward stylus over the connector center. The X/Y coordinates should read close to zero. If not, something's wrong.
Another possibility is that two styli got swapped at calibration. Test the same way.
