RECALL option Not working, Get error
Hi, So I want to say since 2019 the Option to Recall ( Not Recall Feature Points ) doesn't work. So creating a 3d Line from Center ID to Center ID I can not do. It only lets me do RFP Option, that's just to max which I obviously don't want.
Is there a fix? I keep getting an erro no matter what I try.
I need to Calculate and Angle from a Center Shaft to 6x Bore Holes around it.
You may need to update service pack.
Same thing happened to me with 2020.
I would select the 2 circles and get the error. Just closed the feature and the 3d line was there when I clicked on the 3d line feature again.
Center ID to Center ID???
I might consider a Perpendicular Construction using a bore hole as Feature1 and the center shaft as Feature2. Repeat for all 6 hole. Then, Angle between features select 2 Perpendiculars.
UPDATE,
So The error occurs after I select my two features.. I just hit cancel, then X out the menu box. The features and data stays and no issue. It looks like Selecting features trips something out even tho there seems to be no actual error.
Thanks Tom, The Perp construction is more detailed on what I want. I originally just 3d lined them all to the center ( each one ) and got the same as the Perp way you suggested. I like your way better.
Thanks.
I have this issue with both Recall Feature Points and Recall. There doesn't seem to be any actual error, it just pops up a dialogue box and once you close it, everything seems fine. I'm using Calypso 2020, SP1, 7.0.02
So if open the 3d line, select recall, select the 2 features and get the error prompt. Hit cancel on the error, the click the X box on the top right to just close the 3d line window. The data stays and the feature is created. The Error seems to be some random "confusion" that calypso has. The 3d line does create and does work if you jus tx out of it after selecting the features.
