[Si...] Posted March 10, 2022 Share Posted March 10, 2022 Hi, So I want to say since 2019 the Option to Recall ( Not Recall Feature Points ) doesn't work. So creating a 3d Line from Center ID to Center ID I can not do. It only lets me do RFP Option, that's just to max which I obviously don't want. Is there a fix? I keep getting an erro no matter what I try. I need to Calculate and Angle from a Center Shaft to 6x Bore Holes around it. Link to comment Share on other sites More sharing options...
[SH...] Posted March 10, 2022 Share Posted March 10, 2022 What you mean by RFP option,, 😕 Sounds wired...your problems Link to comment Share on other sites More sharing options...
[Ma...] Posted March 10, 2022 Share Posted March 10, 2022 You may need to update service pack. Same thing happened to me with 2020. I would select the 2 circles and get the error. Just closed the feature and the 3d line was there when I clicked on the 3d line feature again. Link to comment Share on other sites More sharing options...
[To...] Posted March 10, 2022 Share Posted March 10, 2022 Please sign in to view this quote. Center ID to Center ID??? I might consider a Perpendicular Construction using a bore hole as Feature1 and the center shaft as Feature2. Repeat for all 6 hole. Then, Angle between features select 2 Perpendiculars. Link to comment Share on other sites More sharing options...
[To...] Posted March 10, 2022 Share Posted March 10, 2022 Please sign in to view this quote. Recall Feature Points.... Link to comment Share on other sites More sharing options...
[Si...] Posted March 10, 2022 Author Share Posted March 10, 2022 Please sign in to view this quote. RECALL FEATURE POINTS. Link to comment Share on other sites More sharing options...
[Si...] Posted March 10, 2022 Author Share Posted March 10, 2022 Please sign in to view this quote. Ok, Ill try that. Link to comment Share on other sites More sharing options...
[Si...] Posted March 10, 2022 Author Share Posted March 10, 2022 UPDATE, So The error occurs after I select my two features.. I just hit cancel, then X out the menu box. The features and data stays and no issue. It looks like Selecting features trips something out even tho there seems to be no actual error. Link to comment Share on other sites More sharing options...
[Si...] Posted March 10, 2022 Author Share Posted March 10, 2022 Please sign in to view this quote. Thanks Tom, The Perp construction is more detailed on what I want. I originally just 3d lined them all to the center ( each one ) and got the same as the Perp way you suggested. I like your way better. Thanks. Link to comment Share on other sites More sharing options...
[Za...] Posted March 10, 2022 Share Posted March 10, 2022 Please sign in to view this quote. I have this issue with both Recall Feature Points and Recall. There doesn't seem to be any actual error, it just pops up a dialogue box and once you close it, everything seems fine. I'm using Calypso 2020, SP1, 7.0.02 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 14, 2022 Share Posted March 14, 2022 Please sign in to view this quote. Same thing on our CMM and Plannar. 🙄 Link to comment Share on other sites More sharing options...
[Si...] Posted March 16, 2022 Author Share Posted March 16, 2022 Please sign in to view this quote. So if open the 3d line, select recall, select the 2 features and get the error prompt. Hit cancel on the error, the click the X box on the top right to just close the 3d line window. The data stays and the feature is created. The Error seems to be some random "confusion" that calypso has. The 3d line does create and does work if you jus tx out of it after selecting the features. Link to comment Share on other sites More sharing options...
