[ca...] Posted June 23, 2022 Share Posted June 23, 2022 Hello everyone, I want to create a gom script which should be automatically run when opening a specific project file. In another way of saying, opening that specific file should trigger the running of the script. Is there a way to do that? Many thanks, Canset Link to comment Share on other sites More sharing options...
[Mi...] Posted June 23, 2022 Share Posted June 23, 2022 Hi Canset, You could use a Windows Shortcut to start a script which opens the specific project and runs your Script... if this could be a solution. Regards Michael Link to comment Share on other sites More sharing options...
[ca...] Posted June 23, 2022 Author Share Posted June 23, 2022 Hi Michael, Many thanks for the quick response. How can i create the windows shortcut to start gom inspect externally? Thanks, Canset Link to comment Share on other sites More sharing options...
[Mi...] Posted June 27, 2022 Share Posted June 27, 2022 Hi Canset, just use a windows shortcut to your start_gom.exe and give them the aditional parameters atos -eval plus the script path like "gom.script.userscript.scriptfolder__script()" should look like this f.e. "C:\Program Files\GOM\2021\bin\start_gom.exe" atos -eval "gom.script.userscript.scriptfolder__script()" Link to comment Share on other sites More sharing options...
[ca...] Posted June 27, 2022 Author Share Posted June 27, 2022 Hi Michael, Many thanks, it works. I have one last question. This start shortcut start_gom.exe only applies for GOM Inspect Pro, right? Is there a way to open blade inspect pro ? Link to comment Share on other sites More sharing options...
[Na...] Posted June 27, 2022 Share Posted June 27, 2022 Hello cansetm, try adding this for Blade Inspect Pro: -license gom-inspection-pro,blade,gom-advanced-blade-inspection Regards, Nanno Link to comment Share on other sites More sharing options...
[ca...] Posted July 19, 2022 Author Share Posted July 19, 2022 Hello Nanno, Many thanks for the quick response, it works. Canset Link to comment Share on other sites More sharing options...
[An...] Posted May 21, 2024 Share Posted May 21, 2024 Please sign in to view this quote. Hi, I have the same need with Blade Inspect Pro 2021, I tried this way but it doesn't work: "C:\Program Files\GOM\2021\bin\GOMSoftware.exe" atos,gom-inspection-pro,blade,gom-advanced-blade-inspection -eval 'gom.script.userscript.test ()' Blade Inspect Pro 2021 starts but the script does not run. thanks Antonio Link to comment Share on other sites More sharing options...
[Na...] Posted May 21, 2024 Share Posted May 21, 2024 Hi Antonio, I think the correct path is missing. It should read: "C:\Program Files\GOM\2021\bin\start_gom.exe" atos -eval "gom.script.userscript.scriptfolder__script()" For the Kiosk it is ""C:\Program Files\Zeiss\INSPECT\2023\bin\ZEISS_INSPECT.exe" -kiosk -fullscreen -eval gom.script.userscript.KioskInterface__Start()"" for example. Link to comment Share on other sites More sharing options...
[An...] Posted May 21, 2024 Share Posted May 21, 2024 Please sign in to view this quote. thanks for the reply, but unfortunately the path was correct, here are some screenshots: Link to comment Share on other sites More sharing options...
[Mi...] Posted May 22, 2024 Share Posted May 22, 2024 Hi Antonio, I think the problem lies in the choice of quotation marks. Does not work: 'gom.script.userscript.test()' Should work: "gom.script.userscript.test()" or simply gom.script.userscript.test() Please also use -license in front of your license selection on the command line. Link to comment Share on other sites More sharing options...
[An...] Posted May 27, 2024 Share Posted May 27, 2024 Please sign in to view this quote. thanks, the problem has been solved! Link to comment Share on other sites More sharing options...
