MMB's.... again
You changed your ? on me. 🤣
Yes and no. You'll get the MMB from -B- but not from -C-. And the MMB calculation needs to consider both features, even though there is a datum precedence. So the fitting for -B- at MMB isn't necessarily the best for for B & C together at MMB.
My thoughts :
The Best Fit applies the MMC(B) of -B- but doesn't allow any additional rotation (MMC of -C- for FFS), it just adds the MMC(B) of -C- to the tolerance.
You could try a Geometry best fit, or try using the best fit within the FFS evaluation.
Also does Calypso really handle MMB or do you mean MMC from older Y14.5 ?
Good luck !
The thing is, you can‘t have the MMC on C as a feature, because it’s not a Feature of Size (the feature would have to have a surface with opposing points to be a FOS), but you can use the MMB on C as a datum, since an MMB is fixed in perfect form, location and orientation anyway.
By the way, it appears, you‘d be much better off functionally, if it wasn’t A|B|C, but B|A|C, because B is mainly functionally responsible for the orientation of the part.
No apology needed, Tom. I do the same thing. I was laughing because I did exactly that and changed my post after I saw you changed your post, thinking that I didn't read your post carefully enough. 🤣
Can't you create a second BFBP with respect to ABC and give MMB to B and C, then you can hide (mark) that true position from the report??
Calypso will not Support MMB on profile tolerance DRF?
Unfortunately, you are not able to use MMB on Profiles.
However, I have it from a reliable source that Zeiss has this high on their action item list.
