[Ri...] Posted March 2, 2022 Share Posted March 2, 2022 If any of you with experience or knowledge, I need the Pros and Cons of using star probes on an XXT RDS CAA. Personally, I don't see the need for them and I see them as limiting the capabilities of the RDS. Link to comment Share on other sites More sharing options...
[Ro...] Posted March 2, 2022 Share Posted March 2, 2022 Hi Rick, My 2 cents.. Star probes are fine on the XXT if they're balanced and being used straight down in Z. Once you rotate in any axis other than Z you end up with a cantilevered probing system. Depending on the weight, that can create some accuracy issues. I only use a star probe in the Z axis, and only to measure things like undercuts and hard to access features. I prefer to use an L probe that's super light if I need to get into a difficult probing area. The overall weight is less and I seem to have less problems calibrating and getting repeatable, accurate results. Link to comment Share on other sites More sharing options...
[To...] Posted March 2, 2022 Share Posted March 2, 2022 Not sure you can create a star probe using CAA. When it first came out, you were able to create a down stylus and a lateral stylus. However, I can't make that work anymore. Likely, something I'm doing wrong. Link to comment Share on other sites More sharing options...
[Ph...] Posted March 3, 2022 Share Posted March 3, 2022 We use star probes but they are all balanced (same size styli on opposite vectors) and we only rotate around the -A-. Qualifying a star probe I have to have a second reference sphere position, Inclination 180° and Rotation 0.0° to avoid shanking out. Link to comment Share on other sites More sharing options...
[To...] Posted March 3, 2022 Share Posted March 3, 2022 Please sign in to view this quote. CAA qualification? Link to comment Share on other sites More sharing options...
[Ja...] Posted March 3, 2022 Share Posted March 3, 2022 Pros of star probe: 1) Depending on the length of stylus system, using RDS XXT head (B axis) narrows down your allowable clearance cube from the axis end positions of CMM meaning you need to place part with enough clearance so that travelling to any clearance planes does not hit the limit switches. This will be the case when part is wide and/or length of stylus system is high. In such cases, only a star probe will work. 2) With B axis at 90°, Z axis will hit the limit switch when probe center about 2 inches from the granite surface, so you cannot probe features that are close to granite surface. While a star probe can probe very close to the granite depending on its structure. 3) It is fairly easy for body of XXT head with B axis rotated to hit/touch/scrape against the fixture or the part itself without getting a collision error. While with start probe, stylus shaft gets shanked instead of the XXT head, much better and less expensive fix, except for when the part is longer than stylus length where head also needs to be lowered into the part to measure a feature. Cons of star probe: 1) Calibration sigma values can be higher than XXT head rotated simple down probes. 2) Rotating to different (A and B) angles provide more flexibility with a single stylus system than having to have individual separate angled stylus systems. Maybe someone can add more to this. Link to comment Share on other sites More sharing options...
[Ph...] Posted March 3, 2022 Share Posted March 3, 2022 I use a passive qualification on all star probes using a Vast XXT-TL-3 RDS-CAA Head Link to comment Share on other sites More sharing options...
[To...] Posted March 3, 2022 Share Posted March 3, 2022 Please sign in to view this quote. Right, but you're not using the CAA function? Link to comment Share on other sites More sharing options...
[Ph...] Posted March 3, 2022 Share Posted March 3, 2022 No I am not but Rick only asked about pros and cons using star probes on that head. Not about CAA Function. Link to comment Share on other sites More sharing options...
[To...] Posted March 3, 2022 Share Posted March 3, 2022 Please sign in to view this quote. One might assume that when you include the term CAA, that you might be trying to use the CAA function. Otherwise, why include it. However, I will not continue to beat this dead horse 🤣 Link to comment Share on other sites More sharing options...
[Lo...] Posted March 4, 2022 Share Posted March 4, 2022 I use a balanced star probe, all four Styli are exactly the same, for a few high production jobs. Not having to rotate the head saves us several hours a week in run time. Link to comment Share on other sites More sharing options...
[Ja...] Posted March 4 Share Posted March 4 Found this on google. Enjoy.helpjuice_production_uploads_upload_image_5216_direct_1570037765954-RDS-CAA_Qualification_Nagel.pptx Link to comment Share on other sites More sharing options...
[Ri...] Posted March 4 Author Share Posted March 4 Well, if you can add an "L" probe to a RCAA stylus system, then why not a star configuration? All you are doing is adding a "List" of articulations. Link to comment Share on other sites More sharing options...
[Ri...] Posted March 5 Share Posted March 5 I've added an L to a CAA stylus system once, and it was just not worth the headache. If you want to attempt it, you have to start with a down facing probe (-Z facing) probe, then you can add your additional styli. It will give you the option of how many rotations you want to qualify that stylus with. Good luck. Link to comment Share on other sites More sharing options...
[To...] Posted March 5 Share Posted March 5 Please sign in to view this quote. It would be nice to be able to have a CAA version of single lateral stylus. In some applications, having the -Z stylus restricts the accessibility improvements gained with the horizontal stylus. Link to comment Share on other sites More sharing options...
[Te...] Posted March 5 Share Posted March 5 The Duramax is an XXT and you use star probes all day on that. The advantage of a Star Probe with the RDS is you are not losing measurement volume because you are not rotating the head. Link to comment Share on other sites More sharing options...
