Cad Model Modifcation/Alignment Question.
I think you are wanting to use the "Keep Position" feature. When you create a new alignment, if you want to feature to keep the coordinates relative to the new alignment, and physically move hit the checkmark under the alignments tab.
If you don't want the holes to move, then make sure "Keep Position" is turned off, and the only thing that will change are the reference dimensions to locate the features.
If you do not check that, the coordinates will change but the feature will not move. Please see the attached images for examples 4326_2b3a88b2fce6496c717c5e86da8d4c95.jpg
When changing the alignment the circle moves to the new orientation 4326_65f30a147968e59acf2f4e28e96623e1.jpg
