Add time and date to .chr under group1 group2
Group1 - group10 is occupied with the group hierarchy in characteristics list so I don't think you can use that. But you can easily create new columns with PCM command generateTableColumn()
Syntax:
generateTableColumn(column ID,function name)
You need to create a function that outputs the date and another that outputs the time if you want it separate columns. A function can have many lines and calculations so you are not limited to what you can do in a single line.
Example.
Insert into presettings of the program or in external PCM-file. This should generate a column with header Date and the the string that you specify in the DateCustom variable. Do the same for Time.
defineFunctionStart("Current date")
DateCustom = date()   //Here you can play around and specify your own date format. Since I'm Swedish I fancy the ISO-standard version YYYY-MM-DD but if you are American I guess you want all the numbers at random with some random separators in there like DM/YM\YD\YY ;)
defineFunctionEnd("DateCustom")
generateTableColumn("Date","Current date")
