Automatic Healing
I have a program checking two separate surface profiles, using FFS from recalled 3d curves.
Yesterday the program gave "normal" results. Today I run the program and get deviations of
178mm on one and 7mm on the other. Normally I see deviations of .03 - .04 microns.
After eliminating the stylus as the problem, and re-building the FFS, still the same results.
I then healed the model and that immediately fixed the problem. In 23 yrs I don't remember
this ever happening.
