Private Messaging is activated - check "How to" on how to disable it Γ—
Need help adding angles using a VAST XXT probe
Hello. I am trying to add probe angles using a VAST XXT RDS-CAA. I am running Calypso 2021 on a Contura. I am using a single point, and not a star probe. I am needing to go from A0,B0 to A90,B90. Thank you!
  • 2 weeks later...
  • 5 weeks later...
Is there a way to have it so when i select a new angle, I won't need to qualify it. Basically when i need a new angle, its tedious to have to break out the calibration set. Feel like there should be a way where it stores a set value for any additional angles. Thanks in advance
We have about 30 standard angles we use in addition to the standard five. For example...
0,45
0,-45
90,45
90,-45
0,30
0,-30
90,30
90,-30
We just have to make sure we do not shank out the probe.
It is important to note that using the CAA calibration option, although it reduces total cal. time, sacrifices some accuracy. I just finished a training at Zeiss in Maple Grove last week, and the trainer confirmed this (although he had a better explanation as to why).
Jeff Frodermann
Meier Tool & Engineering
Anoka, Minnesota
Aaron,
CAA is an option that has to be "turned-on," for lack of a better definition, by Zeiss. Usually, the hardware tech. who calibrates our machine enables it, but perhaps Zeiss can do this remotely.
Jeff Frodermann
Anoka, Minnesota
Aaron, How old is your machine? Look under the RDS unit. Does it say "RDS-CAA" in large red letters? If not, your machine does not have the capability. Do you have a TL-1 sensor? I believe TL-1 is not capable of RDS-CAA.
It does have the RDS-CAA in red, its a 2010 contura g2. Also it is a TL1, although we are having issues with it and will soon be replaced with a TL3 model within a few days to a week.
Interesting. I was under the impression that if you had those letters, you had the option.
When you create a NEW stylus system, is the RDS-CAA checkbox option not available?
Not a new stylus. A new stylus system. If you're trying to add angles to an existing stylus system that wasn't created as RDS-CAA you wont have the option.
Have you tried creating a brand new stylus system as RDS-CAA?
Aaron,
As I mentioned, you need to contact Zeiss to have them turn on the CAA option. It has to do with files that communicate with the controller.
Jeff Frodermann
Anoka, Minnesota
