[Ja...] Posted January 8, 2022 Share Posted January 8, 2022 Hello. I am trying to add probe angles using a VAST XXT RDS-CAA. I am running Calypso 2021 on a Contura. I am using a single point, and not a star probe. I am needing to go from A0,B0 to A90,B90. Thank you! Link to comment Share on other sites More sharing options...
[To...] Posted January 10, 2022 Share Posted January 10, 2022 See attached. Click Icon at top. Enter desired angles. Then, click Rotate axes on machine icon.Screenshot 2022-01-10 075441.jpg Link to comment Share on other sites More sharing options...
[Te...] Posted January 24, 2022 Share Posted January 24, 2022 Here are my recommended angles for Styli 1 thru 5 Link to comment Share on other sites More sharing options...
[Aa...] Posted February 22, 2022 Share Posted February 22, 2022 Is there a way to have it so when i select a new angle, I won't need to qualify it. Basically when i need a new angle, its tedious to have to break out the calibration set. Feel like there should be a way where it stores a set value for any additional angles. Thanks in advance Link to comment Share on other sites More sharing options...
[RA...] Posted February 23, 2022 Share Posted February 23, 2022 Hello, At the time of creating the new configuration. select the RDSCAA option. That way you can interpolate any degree multiple of 2.5ΒΊRDSCAA.jpg Link to comment Share on other sites More sharing options...
[Er...] Posted February 23, 2022 Share Posted February 23, 2022 Please sign in to view this quote. We have about 30 standard angles we use in addition to the standard five. For example... 0,45 0,-45 90,45 90,-45 0,30 0,-30 90,30 90,-30 We just have to make sure we do not shank out the probe. Link to comment Share on other sites More sharing options...
[Je...] Posted February 23, 2022 Share Posted February 23, 2022 . Please sign in to view this quote. It is important to note that using the CAA calibration option, although it reduces total cal. time, sacrifices some accuracy. I just finished a training at Zeiss in Maple Grove last week, and the trainer confirmed this (although he had a better explanation as to why). Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment Share on other sites More sharing options...
[Aa...] Posted February 23, 2022 Share Posted February 23, 2022 I don't have that icon available to check, wonder why? (rds-caa) Link to comment Share on other sites More sharing options...
[Je...] Posted February 23, 2022 Share Posted February 23, 2022 . Please sign in to view this quote. Aaron, CAA is an option that has to be "turned-on," for lack of a better definition, by Zeiss. Usually, the hardware tech. who calibrates our machine enables it, but perhaps Zeiss can do this remotely. Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota Link to comment Share on other sites More sharing options...
[RA...] Posted February 23, 2022 Share Posted February 23, 2022 T Please sign in to view this quote. he option must be defined at the time of creating the Stylis configuration Link to comment Share on other sites More sharing options...
[Aa...] Posted February 23, 2022 Share Posted February 23, 2022 there is not at check box at time of creating a probe, in process of talking to the installer to see what is going on. Link to comment Share on other sites More sharing options...
[To...] Posted February 24, 2022 Share Posted February 24, 2022 Please sign in to view this quote. Aaron, How old is your machine? Look under the RDS unit. Does it say "RDS-CAA" in large red letters? If not, your machine does not have the capability. Do you have a TL-1 sensor? I believe TL-1 is not capable of RDS-CAA.rds-caa.jpg Link to comment Share on other sites More sharing options...
[SH...] Posted February 24, 2022 Share Posted February 24, 2022 Please sign in to view this quote. I have this letter but software don't have that option!!! Link to comment Share on other sites More sharing options...
[Aa...] Posted February 24, 2022 Share Posted February 24, 2022 It does have the RDS-CAA in red, its a 2010 contura g2. Also it is a TL1, although we are having issues with it and will soon be replaced with a TL3 model within a few days to a week. Link to comment Share on other sites More sharing options...
[To...] Posted February 24, 2022 Share Posted February 24, 2022 Please sign in to view this quote. Interesting. I was under the impression that if you had those letters, you had the option. When you create a NEW stylus system, is the RDS-CAA checkbox option not available? Link to comment Share on other sites More sharing options...
[Aa...] Posted February 24, 2022 Share Posted February 24, 2022 There is not a checkbox available when creating a new stylus Link to comment Share on other sites More sharing options...
[Ro...] Posted February 24, 2022 Share Posted February 24, 2022 Please sign in to view this quote. Not a new stylus. A new stylus system. If you're trying to add angles to an existing stylus system that wasn't created as RDS-CAA you wont have the option. Have you tried creating a brand new stylus system as RDS-CAA? Link to comment Share on other sites More sharing options...
[Aa...] Posted February 24, 2022 Share Posted February 24, 2022 i did try, we got a new set of probes that needed to be added. None of which gave me that option for RDS-CAA. Link to comment Share on other sites More sharing options...
[Cl...] Posted February 24, 2022 Share Posted February 24, 2022 Please sign in to view this quote. Tom, all I see is a lot of grey hair. π Link to comment Share on other sites More sharing options...
[Je...] Posted February 24, 2022 Share Posted February 24, 2022 . Aaron, As I mentioned, you need to contact Zeiss to have them turn on the CAA option. It has to do with files that communicate with the controller. Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment Share on other sites More sharing options...
[Aa...] Posted February 24, 2022 Share Posted February 24, 2022 Thanks for your help, Also yes i tried with a whole new stylus system. Link to comment Share on other sites More sharing options...
[To...] Posted February 24, 2022 Share Posted February 24, 2022 Please sign in to view this quote. HA HA HA I was trying to stay out of the picture. LOL Link to comment Share on other sites More sharing options...
