[Ke...] Posted June 27, 2022 Share Posted June 27, 2022 Hello, I am trying to track a component between two stereo sets of cameras. I was able to import both sets of measurement data. I have a component defined using a series of points. This component has points tacked to it it that I want to track. The object is in the same field of view of both cameras. When the object moves the points go out of view of one camera set but are still visible in the other set. The points that are tacked I am looking for change in displacement to reference stage. I see the displacement then it skips out on one set of measurement series but its included in the other. I am essentially trying to stitch this displacement data together which I could do in excel but I would prefer to have it computed automatically between the two measurement series. Is this possible? I was able to create a component regions but I am not able to tack a point to track. Any help would be appreciated! Thanks, Link to comment https://qualityforum.zeiss.com/topic/1098-component-tracking-using-multiple-measurement-series/ Share on other sites More sharing options...
[Iv...] Posted August 23, 2022 Share Posted August 23, 2022 Hi Kevin, please contact your local GOM Partner for help. This topic is not so easy to be solve in a forum article. Greetings Ivan Link to comment https://qualityforum.zeiss.com/topic/1098-component-tracking-using-multiple-measurement-series/#findComment-4210 Share on other sites More sharing options...
[Th...] Posted September 26, 2022 Share Posted September 26, 2022 Hi Kevin, have you seen our "Whats new event SW2022"? The new software version pretty much solves your described problem! 🙂 You can now choose measurement series' to be identified in (if you have more than one in your project) during the creation of point components. This simplifies it quite a lot. 😉 Regarding tacking of points and other elements also some workflows are described in the "Whats New". You can now create nominal elements and give them the measurement principle "Tack to component". If further questions arise: dont hesitate to ask, or contact your local partner for further help. Best, Thorsten Link to comment https://qualityforum.zeiss.com/topic/1098-component-tracking-using-multiple-measurement-series/#findComment-4690 Share on other sites More sharing options...
[Ke...] Posted July 6, 2023 Share Posted July 6, 2023 Thank you Thorsten, Where is there a copy of this what's new document? Thank you! Link to comment https://qualityforum.zeiss.com/topic/1098-component-tracking-using-multiple-measurement-series/#findComment-8173 Share on other sites More sharing options...
[Th...] Posted September 21, 2023 Share Posted September 21, 2023 You can find them in the Zeiss Quality Suite in the "Training" and search for "Highlights for 3D Testing in GOM Correlate 2022" Link to comment https://qualityforum.zeiss.com/topic/1098-component-tracking-using-multiple-measurement-series/#findComment-8880 Share on other sites More sharing options...
