BaseSystem with loop and termination criterion
Hallo all,
I have a test plan. A loop is stored in the base system (10 runs as an example) with the termination criterion baseSystem().valueA<0.02.
When I start the test plan, it works.
If I start the test plan with a starting system, then the base system is measured following, but the loop is not processed.
My question is, why is the loop not processed when I start the test plan with the start system?
[/img]
  • 3 weeks later...
Hi Winfried,
I do recognize your findings with this BaseSystem.
Since we've upgraded Calypso from version 6.8.28 to 7.2.04 this doesn't work anymore.
This is a bit annoying, because in the new version I've to interrupt the program after the start alignment and the 1st base alignment. The loop doensn't work in this situation.
When starting the program again with base alignment[CNC] the loop function works fine then.
Do I miss something or is there a solution for this ?
Many thanks.
