[Me...] Posted February 3, 2022 Share Posted February 3, 2022 Hallo all, I have a test plan. A loop is stored in the base system (10 runs as an example) with the termination criterion baseSystem().valueA<0.02. When I start the test plan, it works. If I start the test plan with a starting system, then the base system is measured following, but the loop is not processed. My question is, why is the loop not processed when I start the test plan with the start system? [img][/img] Link to comment Share on other sites More sharing options...
[Da...] Posted February 3, 2022 Share Posted February 3, 2022 Please sign in to view this quote. I think I've seen this in 2020 version. But I haven't tried the latest SP or patches. If you check CNC measure start alignment you should be fine. Link to comment Share on other sites More sharing options...
[Mi...] Posted February 3, 2022 Share Posted February 3, 2022 What version are you using? The newest version I've tried to loop and use a start alignment is 2018, 6.6.28, and it still works. Hopefully you're using a newer software version and this is fixed with a patch. Link to comment Share on other sites More sharing options...
[An...] Posted February 3, 2022 Share Posted February 3, 2022 - Link to comment Share on other sites More sharing options...
[Ja...] Posted February 3, 2022 Share Posted February 3, 2022 Check actual baseSystem().valueA using result element characteristic at the end of your program run. Is it above your "0.02"? If not then try a lower value in the criterion or better yet, remove criterion and check if the program loops. Link to comment Share on other sites More sharing options...
[Er...] Posted February 4, 2022 Share Posted February 4, 2022 The background printout will show as the program runs. When Calypso calculates the delta it will show it briefly. Also when the Base Alignment features are being measured there should be <1> after them in the upper left of the screen. Link to comment Share on other sites More sharing options...
[Do...] Posted February 22, 2022 Share Posted February 22, 2022 Please sign in to view this quote. Hi Winfried, I do recognize your findings with this BaseSystem. Since we've upgraded Calypso from version 6.8.28 to 7.2.04 this doesn't work anymore. This is a bit annoying, because in the new version I've to interrupt the program after the start alignment and the 1st base alignment. The loop doensn't work in this situation. When starting the program again with base alignment[CNC] the loop function works fine then. Do I miss something or is there a solution for this ? Many thanks.BaseSystem settings.png Link to comment Share on other sites More sharing options...
