Datum Modifier - Maximum Material Boundary (MMB) Check
How to inspect the part with datum modifier example PROFILE TOLERANCE 0.0900 TO DATUM A | BⓂ | CⓂ. Do we have option in GOM 2021 to call for Datum Modifier
Hi Arun,
you first have to check the elements either with independency principle, envelope principle or linear size because the size is needed
for the computation.
You will find those checks in I-Inspect -> GD&T Quick Creation.
Afterwards you can simply enable the usage of MMR inside of the create datum system dialog
Hope this helps.
Best regards
Dinko
