Complex Hole Position
Hey all,
I had a part that I came across with a pretty complex hole position callout (mainly the lower tier) that I thought you guys might enjoy.
I'm attaching a zip archive that has a sample drawing, and CAD model of a similar sketch that I made myself.
I came up with a measurement plan that seemed to work well, but it was kind of a pain to do.
I'd be interested to hear from the community on their thoughts on the drawing, and how they might go about inspecting this in Calypso.
Happy Friday, and enjoy.
Thanks.
GD&T Test - 2-11-22.zipFetching info...
Where is the location of each holes?. No basic dimensions. Dimensions are clear in the drawing,i would go with best fit bore pattern.
Does BFBP work on a group of angled holes? Normally, an angled hole needs to have the axis of the coordinate system tilted normal to axis of hole, i.e. using the Special button or a secondary alignment.
No it does not.
GOM Inspect has this really neat button that will automatically tilt the axis for you. Would be cool to have that in Calypso.
