[Ca...] Posted February 14, 2022 Share Posted February 14, 2022 I'm trying to run parts in Autorun, because there are over 500, and they only run for a few minutes. I've done this before, but not for a while, and the last time I did it, I was using the Custom Printout, and I've since switched to PiWeb. What I want, is to run all 72 parts, and have 72 PDF's dumped into a folder somewhere. I can't seem to make it work. I suspect I'm close in Resources>Results to File, but I'm not sure. Do I need to set a PDF printer as my default on my computer? Link to comment Share on other sites More sharing options...
[Jo...] Posted February 14, 2022 Share Posted February 14, 2022 Please sign in to view this quote. I use multiple printout dialog. Select the PiWeb report and check the icon to display or file. You can specify destination and naming convention. Link to comment Share on other sites More sharing options...
[Ca...] Posted February 14, 2022 Author Share Posted February 14, 2022 John, I think this is exactly what I needed, thanks! Link to comment Share on other sites More sharing options...
[4e...] Posted February 14, 2022 Share Posted February 14, 2022 Please sign in to view this quote. See attached. It's an old document I made, I think using 6.8, but hopefully it helps.PDF instructions.pdf Link to comment Share on other sites More sharing options...
