rotation slots distance + radius
Hi all,
I need to check the distance of those slot (they vary 4 x 90° or 3x 120° but this doesn't matter) the questions is :
I have done pattern on them and how do I output the distance ? Before I have not used pattern so I could used formula distance + circle radius but it just taking a lot of time. Any idea to do this quick please ?
If you have curve you can scan the radii and use the min or max coordinate point for you distance from plane. So if that plane surface is X zero, you would pull the curve into the min/max coordinate and choose the X axis use min coordinate for the radius on the left and max coordinate for the radius on the right.
