[Da...] Posted February 11, 2022 Share Posted February 11, 2022 Hi all, I need to check the distance of those slot (they vary 4 x 90° or 3x 120° but this doesn't matter) the questions is : I have done pattern on them and how do I output the distance ? Before I have not used pattern so I could used formula distance + circle radius but it just taking a lot of time. Any idea to do this quick please ? Link to comment Share on other sites More sharing options...
[Cl...] Posted February 11, 2022 Share Posted February 11, 2022 For plane to OD radii, use; Size > Distance > Caliper distance (between maximum). Link to comment Share on other sites More sharing options...
[Da...] Posted February 11, 2022 Author Share Posted February 11, 2022 Do not have that option in my Calypso 5.4 unfortunately. Link to comment Share on other sites More sharing options...
[Cl...] Posted February 11, 2022 Share Posted February 11, 2022 If you have curve you can scan the radii and use the min or max coordinate point for you distance from plane. So if that plane surface is X zero, you would pull the curve into the min/max coordinate and choose the X axis use min coordinate for the radius on the left and max coordinate for the radius on the right. Link to comment Share on other sites More sharing options...
