Multiple concerns.
I am having issues that I could use some insight on. The first issue I am experiencing has to do with the default graphics, when I open a new window and begin to measure a part. The problem is that you cannot see what your actually checking until you select one of the view buttons (show all geometric features in cad). Then you can see the part, and once that is clicked, I then have to select the (show cad model with surfaces) button so that the planes are not solid.
The second issue, whenever I open a characteristic such as cartesian distance for example. When I click the graphic for the feature, it will select multiple features every time. I only click on one feature but get multiple selected in characteristic box.
Lastly, after I beep a circle and press enter. It defaults to 1000 single point circle path. I cannot seem to get that to go away.
I know it is a lot to ask, but any help would be appreciated.
2nd item. Yes, this is normal. Let's say you created 2 circles in a cylinder Then, you created a position. Then, using Define/Select Geometry and click the cylinder wall. It will see 2 features attached to that surface and populate the first two open choices. In those cases, you might get lucky and it put the correct feature in the correct spot and you'll only need to remove the 2nd feature. Or, you'll need to populate each feature from the list. Doesn't happen often though. Unless the first problem is causing issues.
For the "lastly" go to Resources > Load/Save Defaults Click the Strategy tab and then select the wrench next to Circle. Open the Circle Path and edit the number to what you want. Just curious. Why do you want it to go away?
For the second, even if i just do a cartesian of a plane to a circle, it will select all of them. Even if i dont use features to construct anything.
To answer the last question, we don't use single points when scanning at our location. I just want it to default to a 380 degree scanned path.
