GearPro with different stylus systems?
Hello everyone,
Is it possible to prepare program in GearPro for profile/lead inspection with one stylus system, but for tip/root diameter in the same program it takes another stylus system and continuous to measure.
Thank you,
I have been so far...
I don`t understand if I need to add the new "Feed in" or "Feed out"?
Problem for me is that after stylus system change it try to go trough the part to internal splines from -Y direction. But how to make it to go from +Z direction?
The stylus system contains stylus no.1 and stylus no.5; Measurement should be with stylus no.5!
Hi,
I've done this without adding an extra feed-in, however it is recommended to always add a feed-in when changing stylii.
Also note for feed out, you may have checked by default : "feed out with feed-in stylus", this may go back to grab the first stylus only to feed-out, pretty useless, instead, just check 'last stylus used'.
Good luck.
GEAR PRO is not designed to have more than one feed-in and feed-out! The stylus system change has to work without any collision and it has to work without additional feed-in/out features.
