[An...] Posted January 31, 2022 Share Posted January 31, 2022 Hello all, after manual alignment, as soon as i point last point, CMM axis is moving to -x direction all the way and then pops up error message... why it goes - x axis? I've set CP is +Z axis. Please see attached Thank you in advance cmm CAPTURE.PNGFetching info... Link to comment Share on other sites More sharing options...
[To...] Posted January 31, 2022 Share Posted January 31, 2022 Something may be wrong with your base alignment. Can you post a screenshot of your base alignment window and cad screen? Link to comment Share on other sites More sharing options...
[An...] Posted January 31, 2022 Author Share Posted January 31, 2022 here is my base alignment Picture2.pngFetching info... Picture1.pngFetching info... Link to comment Share on other sites More sharing options...
[Th...] Posted January 31, 2022 Share Posted January 31, 2022 You haven't defined a X or Y location in your base alignment. Without those I would guess it's filling in the machine zeroes and driving off to the limit switches. You could use your existing side plane for Y and take a single point on one of the left or right side flats for X. Link to comment Share on other sites More sharing options...
[An...] Posted January 31, 2022 Author Share Posted January 31, 2022 But i want to set the arrow in the middle... 2.PNGFetching info... Capture.PNGFetching info... Link to comment Share on other sites More sharing options...
[Da...] Posted January 31, 2022 Share Posted January 31, 2022 Please sign in to view this quote. You can use the cylinder in the center for X and Y. Link to comment Share on other sites More sharing options...
[Th...] Posted January 31, 2022 Share Posted January 31, 2022 Please sign in to view this quote. Click the Special button in your base alignment definition window. Then tick the "Keep original alignment from CAD model" button. This will automatically apply any offsets needed to keep that trihedron right where you want it. Make sure it's where you need it to be before you do this. Link to comment Share on other sites More sharing options...
[An...] Posted January 31, 2022 Author Share Posted January 31, 2022 Thank you all Link to comment Share on other sites More sharing options...
[Ri...] Posted February 1, 2022 Share Posted February 1, 2022 FYI Your Base Alignments do not have to be Datums. They can be any feature you want to use to establish what you want for the Base Alignment. Then you can create an Alignment for Datums. For myself, my base alignments are never used for any measurements of any features. They are only to define where the part is within the volumetric capacity of the CMM. I create a "CNC Alignment" that begins to establish my primary Datum Reference Frame (DRF). Link to comment Share on other sites More sharing options...
[Je...] Posted February 1, 2022 Share Posted February 1, 2022 . That's right on the money, Rick. Using a base alignment for measurement purposes is common but can cause problems. Best practice is to create additional alignments for Datum Reference Frames and for measurement results. Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment Share on other sites More sharing options...
[To...] Posted February 1, 2022 Share Posted February 1, 2022 Please sign in to view this quote. I prefer to use the datum features in the characteristics that have fields for the Primary, Secondary or Tertiary Datum so I can take advantage of Outer Tangential and ISO 5459 settings automatically. This action creates the necessary alignment, Yes, you can create secondary alignments and edit their behavior to do the same but it takes so much more effort. That being said, there are some situations where the secondary alignment does make things easier. I can tell you were a former PC-DMIS programmer. 🙂 Link to comment Share on other sites More sharing options...
[Je...] Posted February 1, 2022 Share Posted February 1, 2022 . hahah, thanks Tom. I agree. OTE & ISO are important to take advantage of. Thanks for mentioning the other option, probably the quicker one, to enable them in characteristics. I actually do not have PC-DMIS experience, but I am the lone Zeiss programmer in my company, so that may be coming in the future 😕 Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment Share on other sites More sharing options...
[To...] Posted February 1, 2022 Share Posted February 1, 2022 Please sign in to view this quote. I only said that because I believe PC-DMIS programmers need to create alignments for everything. I may be wrong. Hey Roberto, what's the scoop?...lol Link to comment Share on other sites More sharing options...
