Error while calibrating probes
We are getting an SDO Error this morning, nothing i ve seen before.
We did the standard "turn everything off for 10 minutes" routine, we've ran a different probe calibration program, so far no luck.
SDO Error -1001
Transfer value to SDO is not defined for these components occurred while opening stylus: +Y
Its giving us errors on almost every stylus.
After a half dozen shut downs and restarts and Qualifications, it just started working right.
Probes started turning green after Qual.
So the fix is just to keep doing the same thing over and over, and one time you will get a different result
