Zip files with PCM, before version 2018
I'm attempting to automate our process of versioning programs... because of Autorun and QC-CALC its better to add the version to the filename AFTER it's used.
I created this in Version 2019:
cur_version_num = getRecordHead("vda_version")
complete_folder_path = getActualInspectionDir()
part_num = strElement(1," ",getRecordHead("planid"))
program_folder_path_to_part_num = subStr(getActualInspectionDir(),1,(inStr(getActualInspectionDir(),part_num)+7))
program_name = "\"+getRecordHead("planid")
if (confirm("Would you like to update the version number of the program?"+cr()+"					Current Version Number "+cur_version_num+"")) then
			new_version_num=inquireNumber("Please enter the new version number, remember to update every other instance of this program on other CMMs if applicable"+cr()+"									Current Version Number "+cur_version_num+"")
			zipDir(complete_folder_path)
			copyFile(program_folder_path_to_part_num+program_name+".zip",program_folder_path_to_part_num+"Archives"+program_name+" Version "+cur_version_num+".zip")
			deleteFile(complete_folder_path+".zip")
			setRecordHead("vda_version",new_version_num)
endif
It works beautifully when saved in the inspection_pre_save.pcm. I could save local or network files and have it do exactly what I wanted, which is .zip the program folder, copy it to an archive folder and add the version number to it's name.
However, I was frustrated to learn that the simple .zip() function doesn't work before version 2018... And the copyFile() will not copy a program folder.
I think a batch file might be the only solution for all Calypso versions, but I'm not well versed in them at all.
Does anybody have any ideas?
The variables from Calypso will need to be stored wherever you can access them. I am using the results folder. You can store your variables using the following.
if fileExists(directoryPath("results") + "\cur_version_num.txt")
	deleteFile(directoryPath("results") + "\cur_version_num.txt")
endif
addToFile(directoryPath("results") + "\cur_version_num.txt", cur_version_num)
The following is what the batch file will look like.
@ECHO OFF
REM Directory where files that contain the different Calypso vairiables are stored (can be changed)
C:
CD C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results
REM Read variables stored by Calypso
SET /p cur_Version_Num=<cur_version_num.txt
SET /p complete_folder_path=<complete_folder_path.txt
SET /p part_num=<part_num.txt
SET /p program_folder_path_to_part_num=<program_folder_path_to_part_num.txt
SET /p program_name=<program_name.txt
REM Inquire if version number should be changed
:LOOP
ECHO Current Version Number: %cur_Version_Num%
SET /p Input=Would you like to update the version number of the program?
IF /I "%Input%"=="N" (GOTO end)
IF /I "%Input%"=="n" (GOTO end)
IF /I "%Input%"=="Y" (GOTO updateVerNum)
IF /I "%Input%"=="y" (GOTO updateVerNum)
ECHO.
ECHO Invalid Choice
GOTO LOOP
:updateVerNum
REM Enter the new version number
SET /P new_version_num=Enter New Version Number:
REM Store new version number in file
echo %new_version_num% > new_version_num.txt
REM Zip folder
powershell Compress-Archive %complete_folder_path% %complete_folder_path%.zip
copy %program_folder_path_to_part_num%\%program_name%.zip %program_folder_path_to_part_num%\Archives\%program_name%_Version_%cur_Version_Num%.zip
DEL %complete_folder_path%.zip
:end
You will then have to read the new_version_num.txt file to set your new version in the record head.
