Preferred method
I have created several family of parts programs, using .separate para files with all the variables. My colleague did not use separate para files, but instead put all the variables in the presetting's. Clearly both methods work, but is there some any substantial benefit from using one method over the other?
https://qualityforum.zeiss.com/topic/11160-preferred-method/
Some may say it's easier to edit external files, but... And depending on how much variables you have etc. It can be really messy if kept in pre-settings.
The only down side with external files is that you "can't" run the program on a cmm without the pcm license. Which might, or might not be a problem.
I try to keep "program specific" stuff in the program. And generic stuff on external files as functions.
https://qualityforum.zeiss.com/topic/11160-preferred-method/#findComment-54722
  • 1 year later...
Is there another way to get variables from an external file without PCM?
Currently, I'm trying to set a pallet measurement where the worker can type the part number of each part at the very beginning. The corresponding part number should be read at the beginning of each single measurement.
It is working fine with PCM (using the readPCMFile function) but I should get it work on a CMM without PCM...
Does anyone have an idea? ???
https://qualityforum.zeiss.com/topic/11160-preferred-method/#findComment-54730
  • 2 weeks later...
I was able to use the readListFile(filename) function. I created the program with the offline station which has a PCM license and ran the program on a CMM that does not have a license. The following is in the Presettings.
diameter1 = 25
diameter2 = 10
drawingNumber = inquireList("Run","variant1","variant2")
if drawingNumber == "" then
	endInspection()
	cncBreak()
endif
selectCase drawingNumber
	case "variant1"
		theList = readListFile("family\variant1.txt")
		diameter1 = getParameterNamed(theList, 1)
		diameter2 = getParameterNamed(theList, 2)
	case "variant2"
		theList = readListFile("family\variant2.txt")
endSelect
redrawCAD()
https://qualityforum.zeiss.com/topic/11160-preferred-method/#findComment-54732
Here is a similar way but without the selectCase.
diameter1 = 25
diameter2 = 10
	endInspection()
	cncBreak()
endif
theList = readListFile("family\" +drawingNumber)
diameter1 = val(theList.first)
diameter2 = val(theList.second)
redrawCAD()
https://qualityforum.zeiss.com/topic/11160-preferred-method/#findComment-54734
