angle measurement error
This maybe an easy one for some, but it had been puzzling me for a while. When measuring an angle between two features I set the tolerances to +1.00 and -1.00 degree, and as it's shown on the picture, even though the reading is well within the tolerance, the finding is reported as a fail. I am assuming the tolerances are in degrees, not minutes. It should be green, but they are red.
Can anyone tell me how to interpret that?
Thank you
That did it, thank you. The column headers had the symbols + and -, respectively, didn't occur to me that I still have to add the minus sign, but it worked, so thank you !
