No actual data in Blade report
Hi all,
We have 2 CMM and they are running same program and fine.
One day one of them stopped produce blade report, what I could see was the path in the directory option be changed. I copied the specification file from another machine and replaced the old, and then i could have blade report but there is no actual data in it.
Any reasons for it, or some setting to load actual?
  • 2 years later...
Hello,
did you get an errormessage?
Some years ago i had a problem with English language and the solution was the recordhead data.
The .bxd file is zip-file. If you change extension to .zip you can extract the xml file and search for record head data like operator.
If you delete this section and save it again to the folder before, this error is fixed.
I am not shure that this is your error.
Regards
