Centerless grinding
My apologies in advance. I normally wouldn't ask this type of question, but I've seen it done here
a few times before, so thought I'd ask. Not Calypso related, but does anyone out there work for a
company that has a centerless grinder?
Our grinding guy wants to interface a laser measuring system with our Micron MPC 600IV centerless grinder.
To measure and adjust simultaneously on the machine.
Like I said, not Calypso related. Our grinding guy is looking for a laser scanner that interfaces with the centerless grinder to make automatic adjustments. He's getting no response back from the company that sells or makes them, so I told him I'd ask some of you in the forum on the chance you have a contact.
Use to, worked for a medical device company that had 30-40 of them, mostly Glebar's. That's kind of what guy me into programming was the Glebar P4K's.
What kind of information are you looking for? I'm still good friends with the engineers at the company and can ask them.
Regards,
Etamic Movomatic. Inprocess centerless gaging (air gage to electronic) . It's very capable, but, NOT inexpensive. Referred by my coworker. He used them quite a bit.
Hi Clarke,
we are using Marposs gaging devices on our grinding machines, maybe they have a solution for you:
Here's the contact i found from Michigan: 😃
MARPOSS CORP.
3300 Cross Creek Parkway
Auburn Hills MI 48326
Phone: +1 248 3700404
Fax: +1 248 3700991
https://www.marposs.com/eng/
Best regards.
centerless grinder. To measure and adjust simultaneously on the machine. He would like
whatever info he can get.
Thanks.
