[SH...] Posted December 14, 2020 Share Posted December 14, 2020 Any option to join my ployline ends??. I think it will be a simple trick.IMG_20201214_190236.jpg Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/ Share on other sites More sharing options...
[Ja...] Posted December 14, 2020 Share Posted December 14, 2020 in your strategy, copy/paste your first point and move it to the end before you create your polyline. Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55324 Share on other sites More sharing options...
[Ja...] Posted December 14, 2020 Share Posted December 14, 2020 Since it is already created, you can type in the coordinates of your last point to match the first. Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55326 Share on other sites More sharing options...
[SH...] Posted December 14, 2020 Author Share Posted December 14, 2020 But I can't open my points list 🙄 Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55328 Share on other sites More sharing options...
[Ri...] Posted December 14, 2020 Share Posted December 14, 2020 Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55330 Share on other sites More sharing options...
[Ja...] Posted December 14, 2020 Share Posted December 14, 2020 Please sign in to view this quote. If you go in to edit the poly line (speed/ step width), You should also see point coordinates.Poly.jpg Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55332 Share on other sites More sharing options...
[Ow...] Posted December 14, 2020 Share Posted December 14, 2020 You can move it by changing the dimensions (as already shown) but, another way is (It's mysterious at times but), you can zoom in real close to the point you want to move (on cad screen) and with the left mouse click held-down, move it to where you want it to go. Used to be a hand symbol pop-up when you got close to the point but, I'm not seeing that anymore. Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55334 Share on other sites More sharing options...
[Ow...] Posted January 12, 2022 Share Posted January 12, 2022 BUMP- Read my comments made above a little over a year ago, I can't do this anymore. Did they remove this option? I'm aware of the convert to points and move them and then recreate the polyline but, dang-it, just grabbing them with the mouse was easy, or it used to be. 😕 Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55336 Share on other sites More sharing options...
[No...] Posted January 13, 2022 Share Posted January 13, 2022 This feature has always been a bit touchy in my opinion. In some releases it worked very well, in another it was nearly broken, then it worked again....maybe it has to do with the changes in the ACIS part of the software? This polyline conversion thing raises a question in my mind: If I convert a polyline with circle segments to points, will this information be lost? Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55338 Share on other sites More sharing options...
[Ow...] Posted January 13, 2022 Share Posted January 13, 2022 Please sign in to view this quote. Norbert, If the circle or radius section of the polyline has at least 3 nominal points, they will not be lost. As long as you don't move them far enough to break the form of radial tangency, they will go back to circular form when selecting all the points and converting them back using the autopath switch. The picture below show's an example similar to the one I was trying to just grab the points and move, except the one I was trying to adjust was much bigger with 348 nominal points. Needless to say, meticulously adjusting that amount of points without screwing it up is cumbersome. Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55340 Share on other sites More sharing options...
[Ia...] Posted January 13, 2022 Share Posted January 13, 2022 Please sign in to view this quote. Vertical taskbar, a man of class. Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55342 Share on other sites More sharing options...
[No...] Posted January 14, 2022 Share Posted January 14, 2022 Please sign in to view this quote. Cool. 😎 And unexpected. I will definitely use this method from now on. Link to comment https://qualityforum.zeiss.com/topic/11242-joining-poly-line/#findComment-55344 Share on other sites More sharing options...
