[Th...] Posted July 26, 2021 Share Posted July 26, 2021 Update from 2019 to 2021 calypso and now I get this error from time to time randomly. How can I fix it?ERROR.png Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/ Share on other sites More sharing options...
[Da...] Posted July 26, 2021 Share Posted July 26, 2021 i get it every time PiWeb tries to print. Got a call into the Hotline. Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/#findComment-55454 Share on other sites More sharing options...
[ab...] Posted July 26, 2021 Share Posted July 26, 2021 I'm not entirely sure if this is the solution, but I seem to remember something about changing the PiWeb database files from dfm to dfs. I would try launching the utility "ConvertPiWebDatabases" from Start Menu --> Zeiss 1. Locate the folder where your PiWeb databases live. It's probably: C:\Users\Public\Documents\ZEISS\CALYPSO\workarea\PiWebReportingDatabases\ or C:\Users\Public\Documents\ZEISS\CALYPSO 6.8\workarea\PiWebReportingDatabases\ Setup a backup folder (and click 'Create backups') if you want a copy of your old DFMs. 2. Press the List DBs button 3. Convert After you've done this step, close Calypso and re-start it. Open your measurement plan and run the part, or run without clearing existing results. See if PiWeb is able to connect to the new, converted database. If you'd like to be cautious, only convert the 1 database that is linked to this measurement plan only. If it works, do the rest of them. I'm not entirely sure if this is going to do the trick but I do know the database file type changed in newer versions of Calypso so that the PiWeb reports can load much faster, I believe. Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/#findComment-55456 Share on other sites More sharing options...
[Th...] Posted July 26, 2021 Author Share Posted July 26, 2021 Laura, I just did the conversion and it's working so far. No popup error and piweb result is there after program is ran. I think this is the fix. Thanks a lot! 😉 ETA: Talked to Zeiss support and they said to download the Zeiss Piweb patch inside the portal. Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/#findComment-55458 Share on other sites More sharing options...
[Mi...] Posted August 30, 2021 Share Posted August 30, 2021 I seem to be having this same issue. We updated a all 3 of our CMM's from 2020 to 2021 and we are getting this error on 1 of them. We use a custom report for all our parts but today we had a customer come in for a quick online measurement and I used a default report. The report did not generate and the same error showed up. I tried to replicate on the other 2 CMM's and this did not occur. We also updated our PiWeb to 8.0.1.0 other the weekend. Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/#findComment-55460 Share on other sites More sharing options...
[Mi...] Posted September 22, 2021 Share Posted September 22, 2021 I know its an old post but this fixed the issue for mine... Navigate to the Calypso 7.0 workarea folder, here: C:\Users\Public\Documents\Zeiss\CALYPSO 7.2\workarea In that folder you will have a folder called, ““PiWebReportinDatabases”. Re-name that folder “PiWebReportinDatabases_backup” then create a new folder and name it “PiWebReportinDatabases". Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/#findComment-55462 Share on other sites More sharing options...
[In...] Posted January 11, 2022 Share Posted January 11, 2022 Thank you so much! What an easy, great fix! You have saved me another headache 😃 Link to comment https://qualityforum.zeiss.com/topic/11262-error-piweb-cmm-server-not-started/#findComment-55464 Share on other sites More sharing options...
