issue with start alignement's arrows
Hello,
when i define the element's strategy and after the start alignement, sometimes the yellow arrow aren't on top of the plane, can i fix it ? have i to defin a new element ? 3726_0a483751c4b68785c949decf5a731c8d.jpg
another issue : sometimes on start alignement the violet color is on the previous element to probe ! how to fix it ?
Thx
Nicolas
I'm not sure I understand your post but, when using the start alignment, the points on the screen will show off location to the model if it's not in the exact same place it was when the base alignment was created. The start alignment is generally used just to locate the part on the CMM and generally it consist of just a few features that don't take long to take manually and then the program takes off and runs the base alignment features automatically.
As far as the color of the feature on the model, I've seen that before and I'm not sure why it does it sometimes and sometimes it doesn't but, as long as the program is going to the next correct feature, it's nothing to be worried about.
