Surface Profile Question
I seem to be confused on how surface profile is calculated in Calypso. I know that you find the largest deviation OUTSIDE workpiece (Max). Then find the largest deviation INSIDE workpiece (Min). Once that is done A = largest ABSOLUTE value of either Max, or Min. Then the reported actual profile deviation = 2xA. In the images below "Plane2" has a Max of 0.0005". If I plug this into the equation 2xA, the actual profile deviation of Plane2 should be 0.001". When I program the profile characteristic for Plane2, I am getting a profile reading of 0.0254". My FCF reads: surface profile of 0.020 to datum -A-. I have provided a rudimentary sketch of the feature and its orientation according to the WCS as well as the feature related info. What am I missing or doing wrong?
The Min / Max values in the feature come from the coordinates of the feature itself (similar to flatness), then it doesn't consider the Datum A or whatever is your Alignment..
Remember Profile covers form, size, as well as location. Because the 1.650 actual measures 1.6617" and is .0117" from nominal, your results will at least be double, or .0234" If you add the other .0016" from the difference of form error doubled, you are close to the value calypso measures at .0254." It seems to me this calculation is correct. 1417_e00de2da890d8da0d1ab1545760fed47.jpg
