[Da...] Posted December 17, 2020 Share Posted December 17, 2020 Added a text element to a program to write in a dimension that we can't check with the CMM, but nothing shows up on the print out or the screen... 😭 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 17, 2020 Share Posted December 17, 2020 Yes. This is a known issue since 2018 with the implementation of PiWeb Reporting. It is being worked on. Link to comment Share on other sites More sharing options...
[Th...] Posted December 17, 2020 Share Posted December 17, 2020 If you have a custom report managed in the multiple printout menu, make sure the text features box is ticked. Also as Richard says, Piweb doesn't do text elements.mprint.JPG Link to comment Share on other sites More sharing options...
[Da...] Posted December 17, 2020 Author Share Posted December 17, 2020 Seriously, I want a refund !!!! Can't mask , can't text, Pi web has more questions on this forum than anything else !!! 😡 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 17, 2020 Share Posted December 17, 2020 Masking is still there, it's just called Marking now. I am still trying to wrap my head around needing Text Elements, and why people need them so desperately. Link to comment Share on other sites More sharing options...
[Th...] Posted December 17, 2020 Share Posted December 17, 2020 OK, so it is Piweb. Last time I checked, the suggested workaround was to use groups as pseudo-text. Please sign in to view this quote. We use text elements for small bits of info on the printouts our mill operators get. Link to comment Share on other sites More sharing options...
[fd...] Posted December 17, 2020 Share Posted December 17, 2020 Please sign in to view this quote. Yes! In almost 10 years of using Calypso, I've never once needed Text Element! I always am so confused when people say they are so important. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 17, 2020 Share Posted December 17, 2020 I think it's a legacy concept coming from the DMIS days. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 17, 2020 Share Posted December 17, 2020 Please sign in to view this quote. Can you not use the Comment section? I have used this to display offsets for machining operators. Worked well. Link to comment Share on other sites More sharing options...
[Th...] Posted December 17, 2020 Share Posted December 17, 2020 Not offset info, we use them more like category headers, e.g. all the production-specific characteristics go under a text element that prints something like "these are production reference measurements". For this use-case, the aforementioned groups would serve a similar purpose on Piweb reports. As for comments, it looks like there's a fair amount of room in the form templates for readable text, but adding a comment to a simple diameter characteristic results in some very tiny words. Link to comment Share on other sites More sharing options...
[fd...] Posted December 17, 2020 Share Posted December 17, 2020 Please sign in to view this quote. You can always create your own report template. Using the Protocol object, you could have 2 row templates: 1 of which is a row template that has all the space you need for extensive comments. Just a thought? Link to comment Share on other sites More sharing options...
[Ne...] Posted December 21, 2021 Share Posted December 21, 2021 We use text elements to separate process dims from top-level-drawing dims. I also use them for job set-up references that aren't on the blue print. At bigger companies they don't like seeing extra stuff on reports but a text element can clarify the purpose of the "dims below" along with the assurance that they'll be deleted upon first article completion. 👩🏫 Link to comment Share on other sites More sharing options...
[Da...] Posted December 21, 2021 Share Posted December 21, 2021 We use them for set up information, so that the fixturing is exactly the same every time. This is a big help for operators who are running a part for the first time or haven't run it for awhile. We do not include it in the reports, so it stays masked. Also if a program has not been run before we will use text element to alert whoever may run it that it needs to be watched and debugged as needed. Link to comment Share on other sites More sharing options...
[Pe...] Posted December 21, 2021 Share Posted December 21, 2021 I use them mostly for manually checked elements, leaving a blank field for an operator to fill in. For example, a radius that may need checking with an optical, surface finishes, or a threaded feature that has multiple elements that need checking. Text elements can contain formulas too. I once had a part that was very finicky, requiring almost constant adjustment. I made a text element that had a a bunch of calculations and strings that output specific adjustments for multiple offsets and tool comps at the end of the report. Link to comment Share on other sites More sharing options...
[Je...] Posted December 21, 2021 Share Posted December 21, 2021 . Hello. I have found that showing groups in Piweb reports works well for the tasks you mentioned. Comments can be added to each group to relay information. Groups add a clean, organized look. However, if you wish to add Text Elements to your Piweb reports, click the option to Upload Text Elements under Resources > Results to File > PiWeb Reporting [Configuration]. See attached images. . . . Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment Share on other sites More sharing options...
[Ne...] Posted December 21, 2021 Share Posted December 21, 2021 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
