[Ma...] Posted December 20, 2021 Share Posted December 20, 2021 Hello Everyone, I looking for help with PCM. I have one program for several similar parts made with PCM help and I wondering how I can save reports to several directory locations for each part ? Thank you in advance for your help. Link to comment https://qualityforum.zeiss.com/topic/11352-pcm-quotpdf-file-piweb-reportingquot-output-file-to-diffrent-directorys-in-the-same-program/ Share on other sites More sharing options...
[Ma...] Posted December 20, 2021 Share Posted December 20, 2021 Does that path differ so much to use PCM? You could do some adjustment in default file names for PDF. Link to comment https://qualityforum.zeiss.com/topic/11352-pcm-quotpdf-file-piweb-reportingquot-output-file-to-diffrent-directorys-in-the-same-program/#findComment-56006 Share on other sites More sharing options...
[Ma...] Posted December 21, 2021 Author Share Posted December 21, 2021 Hi Martin, Of Course you were right, I don't know why I wanted complicate this more. I made variable in default directory. Thanks for back to right track. Link to comment https://qualityforum.zeiss.com/topic/11352-pcm-quotpdf-file-piweb-reportingquot-output-file-to-diffrent-directorys-in-the-same-program/#findComment-56008 Share on other sites More sharing options...
