VAST XXT REPLACEMENT
I have been tasked with replacing our Vast XXT TL1 due to wear (its almost 8 years old from my understanding). Our current unit had barely passed the calibration we had from Zeiss that we received back in November. Now after a very rough crash by an operator, I had trouble with a re-qualification program and I'm also seeing repeatability issues during scanning. With those issues we chose to replace the unit altogether. The replacement arrives tomorrow and I'm looking to have some information on what to expect when I install the new XXT sensor. I've never had to replace this component so any information you can provide would be helpful. I did speak with the technician on what we'd need to do if we chose to get a new sensor and he made it seem like it was as simple as removing the old unit and then placing the new one on.
Just make sure you run the Device Activator application first. It's available for download on the portal. There's also going to be a bright red card in the XXT box that tells you this.
