Graphic result-Change tolerance
Hello ,
I have two questions :
1) I can't change the tolerance( from 2 decimales in 3 decimales ) , in normal view is OK but in plot protocol (graphic) NOK . I put the photos .
2) Is possible to see the graphic for Profile , because i see the graphic only for line profile?
THANK'S IN ADVANCE
1. Did you tried in Plan editor for characteristics -> Units -> Number of decimal places ?
2. You can view almost everything, but not surface profile. This can be viewed with CAD view / CAD -> Evaluation -> CAD button on bottom of window. Here you can enable visual representation of deviations - I personally use only cylinders.
Btw. Romania and czech protocol?
  • 3 months later...
