Two hole pattern used as a Datum
I've been using Calypso for 16 years and never noticed this feature. Thanks again Jeff, I was able to use the two cylinders as a Datum. I spoke with the engineer about using the top cylinder as Datum C and referencing the bottom cylinder back to C. He was agreeable, so that's how I reported it. I got better numbers using the parallel cylinders but I don't know why. I'll have to study it more before I use it in programs.
I think you should use geometry best fit alignment. Your pattern can constrain five degrees of freedom,but parallel cylinder can only four. Depends upon the placement in the datum reference frame a feature can constrain different degrees of freedom. I think in your case it constrain only rotation.
