Composite Position
What is the best practice for inspecting this composite position. Primarily, the .25mm position to A, B-C?
Assume the 4 holes in questions refer to the position requirement. 1417_48c12d455413d64a0c6634df6c8d69cc.jpg
For the top tier, using B for the Secondary and C for the Tertiaty, the origin of the DRFis at B and the Y axis drives thru C.
For the lower tier, I discovered something that I was not expecting. The origin of the DRF was not at B or the mid-point of B-C. It is at the edge of Plane_A See screen shots.
This is why I asked. I thought B-C would mean the Origin would be The symmetry of the 2 holes. Is this correct to ASME Y14.5, and calypso is using an ISO interpretation, or am I not understanding correctly?
Below is a youtube link that does a decent job describing the multiple single segment feature control frames, in particular at 1:02. The whole video is worth watching. This guy has several videos.
https://www.youtube.com/watch?v=iSdMpgV ... =8&t=3692s
I'm not in front of Calypso so I can't test. What happens when you use A as Primary and B-C as Secondary with regards to best fits? If you open the default printout, it should show you.
My understanding is that B-C creates a line axis of datum that would constrain only 2 translations of freedom
So for the second position you could still use the same datum frame at the tighter tolerance, but you would constrain it to the "Only Y" direction since B-C creates an infinite line that shouldn't care about X.
You would get an odd tolerance zone like this: 3090_46dc845fb10315d8a7f7ae0815e14c8f.png
I believe it may be gathering the Y position from the feature origin of Plane A (or base alignment if you defined one) since the lower tier doesn't define any Y.
Thank you, That makes sense.
They only thing that makes me question where to origin would be is this statement I found in the ASME Y14.5. This is from 2009. If B and C doesn't matter which is listed first, it makes me think that the origin now become the center of the 2. And if that's the case, it may translate to the center of the 2 holes rather than to Datum B in line with Datum C. 1417_0ce4378842742191e021b1293641153e.jpg
Datum B-C is considered 1 datum (codatums) and each hole has equal precedence. The origin is the symmetry of the 2 holes. Level/origin to A, rotate to the axis of B-C, origin to the symmetry of B-C.
