How to eval line profile with ref. angle
Sorry for delay - i rather use real drawings instead handwritten from memory.
This is partly cleared drawing - line profile goes for involute defined by radius which have +/- 0,2mm tolerance and have to sides on part.
No other dimensions are drawn for this ( except from start and end of dashed line of profile )
Part is called in DE - Bremsnocken / translated from CZ to EN - brake key 3001_9f0f74e009dbb39fc3231805ffeeaaa8.png
Looks to me like the drawing wants in addition to the 0.2 tolerance a 0.1 tolerance for every
15° segment? I do see in the drop-down menu of the line profile characteristic and option
named "Evaluate tolerance segments individually".
As we lack in knowledge of involutes I wonder, if are both sides connected somehow. There is no base for eval, so we ended in bestfitting whole sides of involute as pattern.
I did not tried to measure from blueprint drawn segments if they fit 15°. I tried curve jump, but i don't understand it right.
I have model in nominals - so involute is in middle of tolerance - nothing is set as basic dimension so i really don't know if bestfit of both sides as pattern is right.
It would be real pain to divide curve ( we have 4 - 2 sides at two heights ) into segments.
Any guide?
I was looking for "Evaluate tolerance segments individually" and found it. But it gives me only deviations as max and min without doubling it.
We are reporting only one number for this position to customer.
Still can not figure out how to correctly finish it 🙁
Edit: For full drawing there is diameter of center circle labeled as "Circle involute with R +/- tol active camshaft radius" and it is marked as base "A", which is used for symmetry of width.
So can I evaluate each curve independently?
Still it's not resolving my problem. If i would report worst 15° segment and doubling it's value i'll get same value as whole line profile.
In circular slice you just put element and angle of segment.
Since it have no base for eval, then it would have sence to have smaller tolerance for segment. But i don't know if both side are tied up with involute start radius and it's center.
  • 2 months later...
Thanks Guenter, that's at least one good feature of new version.
But i don't think i'll get newer version. Customers sometimes demands our programs to clarify our strategy.
