[Lu...] Posted December 8, 2021 Share Posted December 8, 2021 Hello, where will I learn to work with formulas? Is there a book for it or are you studying it? Thanks Link to comment Share on other sites More sharing options...
[Cl...] Posted December 8, 2021 Share Posted December 8, 2021 What specific formula are you looking for? Link to comment Share on other sites More sharing options...
[Gr...] Posted December 8, 2021 Share Posted December 8, 2021 So there's a lot of overlap between PCM and formulas. There's a PCM instruction manual that lists all the variables that Calypso can work with. Understanding how Calypso calls out variables in a formula is a necessary step to writing them. If you've got a specific problem in mind, post it and let's work through it. If you check the help manuals on your PC, there's probably a file labeled "Calypso_02_PCM.pdf". Mine was located at: C:/Program Files (x86)Zeiss/CALPYSO 7.0/userinfo/manuals/en. Link to comment Share on other sites More sharing options...
[Zo...] Posted December 9, 2021 Share Posted December 9, 2021 to start experimenting right click on any box, if there is formula option click on it on the following window, click on function it will take you to function and parameter list if you don't have PCM, first 3 menus contain most functions available to you _see Pictures 1-3_ you can add variable/parameter by going in Plan > Advanced > Parameter _see picture 4_ once you have added features and characteristics to your plan, you can also use all those actuals and nominals in you formulas _see Picture 5_ picture 6 is a sample of final outcome Snag_46e22fc4.pngFetching info... Snag_46e22564.pngFetching info... Snag_46e21b71.pngFetching info... Snag_46e21288.pngFetching info... Snag_46e201bf.pngFetching info... Snag_46e1f21f.pngFetching info... Link to comment Share on other sites More sharing options...
[Cl...] Posted December 9, 2021 Share Posted December 9, 2021 PCM is where the fun begins! Link to comment Share on other sites More sharing options...
[Ja...] Posted December 9, 2021 Share Posted December 9, 2021 Please sign in to view this quote. That used to work for me but now when I clock on function I get the message "PCM" not available. Link to comment Share on other sites More sharing options...
[Cl...] Posted December 9, 2021 Share Posted December 9, 2021 We pled with management for years to invest, the roughly $9,000 (per seat) for PCM and we finally got it a few years ago. Now we can't live without it. Link to comment Share on other sites More sharing options...
[Zo...] Posted December 9, 2021 Share Posted December 9, 2021 Please sign in to view this quote. possibilities are limitless, once you deep dive into PCM Link to comment Share on other sites More sharing options...
[Se...] Posted December 10, 2021 Share Posted December 10, 2021 PCM is really not easy, but once you're in, you feel like a real programmer! 😎 You will take your programs to the next level. The only limit to the possibilities is your imagination! . Link to comment Share on other sites More sharing options...
[SH...] Posted December 10, 2021 Share Posted December 10, 2021 Please sign in to view this quote. If you don't have pcm. Result element is best tool for formula. I think it is invented for formula. https://youtu.be/-v1-Od7lPUE Link to comment Share on other sites More sharing options...
[No...] Posted December 13, 2021 Share Posted December 13, 2021 Please sign in to view this quote. Don't try this with PCM! 🤣 https://www.youtube.com/watch?v=LtlrITxB5qg Link to comment Share on other sites More sharing options...
