RDS and Vscan Head question
We had a Ziess Tech come in and install our VISCAN Camera. He didn't automate the process. Need help finding a manual on how to teach the machine to automatically change heads.
The tech support from them from the last two visits has been pretty bad. Ive been given the information to contact them. Im rather free on a friday and with the right manual , I should be able to figure it out.
Is there any resources online
It may be as simple as going to the Automatic Stylus System change and adding both RDS Stylus System Holders. One would be for the Viscan, the other for the touch probe.
Open-Automatic Stylus System
Edit-Add stylus system holder-RDS
I would name it Viscan.
Then Define Holder Location
Rinse and repeat for the other RDS holder.
Edit: This all should be in the standard Calypso manual and the Probe Qualification manual
  • 2 weeks later...
This is in the Calypso manual. A pdf should be in the Zeiss folder.
In the manual search for Defining RDS for the instructions. The RDS holders MUST be spaced 170mm minimum per my manual.
