[He...] Posted December 8, 2021 Share Posted December 8, 2021 Hallo zusammen, Bei folgendem Bauteil habe ich das Problem, dass hier bei allen Oberflächen eine Flächenform ausgewertet werden muss. Wie würdet ihr hier von der Messstrategie heran gehen bzw. Auswerten. Bisher habe ich Auswerten von Flächenformen noch nie benötigt und somit hoffe ich auf Tipps für die Herangehensweise. Ich bin um jeden Tipp dankbar. Gruß Heiko 20211208_181950.jpgFetching info... Link to comment Share on other sites More sharing options...
[Er...] Posted December 9, 2021 Share Posted December 9, 2021 Unless Otherwise Specified(UOS) is normally on our prints. I am unfamiliar with QEO-11-410. Maybe UOS is included in it? Applying UOS I use General Surface and take a few points on features without dimensions. I use knowledge of the production process, form, fit, and function to take as few points as possible. General Surface can be tricky to use. I create the feature, rename it, set the alignment, then pick the points. If I need to change it I delete it and start over. Editing has given unpredictable results. Link to comment Share on other sites More sharing options...
[He...] Posted December 9, 2021 Author Share Posted December 9, 2021 Was für Messelemente kann ich ich für die Flächenauswertung benutzen. Mein Gedanke war, das ich einen Schnitt im Bauteil erstelle und somit die Linienkontur vom Einstich habe, dann hätte ich über 2D Kurve den Einstich gescannt. Link to comment Share on other sites More sharing options...
[Da...] Posted December 9, 2021 Share Posted December 9, 2021 Please sign in to view this quote. Erik already catched QEO-11-410. This is probably some internal norm by your customer. Check that. That drawing is to ISO GPS right? If so, be aware that surface profile is meant for each separate geometry in that case (not simultaniously). Another thing, datums B and C are coaxial, so there aren't all Degrees Of Freedom locked with |A|B|C| DRF. Check that with design if you only can. Link to comment Share on other sites More sharing options...
[He...] Posted December 9, 2021 Author Share Posted December 9, 2021 Die Zeichnung ist ISO GPS. Ich habe gedacht ich baue mein Bezugsystem so auf das ich die Durchmesser Bezug C und Bezug B messe, dann über einen Kreis per Punktetückruf auf Bezug C und B und als Primär Bezug A verwende. Mit diesem neuen Bezugsystem hätte ich meine Linieform vom Einstich gemessen. Link to comment Share on other sites More sharing options...
