[Ra...] Posted December 3, 2021 Share Posted December 3, 2021 Do you guys leave the machines just running or do you guys actually power everything down? Link to comment Share on other sites More sharing options...
[Ke...] Posted December 3, 2021 Share Posted December 3, 2021 I leave everything up & running on normal weekends, unless I see bad weather coming through. If the machines will be unused for 4+ days, then I shut it all down. Link to comment Share on other sites More sharing options...
[Te...] Posted December 3, 2021 Share Posted December 3, 2021 I always recommend to my students to shut everything down at least once a week, to at least clean out the temp memory. If you use a lot of freeform and curve this is especially important. I have always found that it just helps Calypso from bogging down. Link to comment Share on other sites More sharing options...
[Er...] Posted December 3, 2021 Share Posted December 3, 2021 If it is just the weekend we power down. The electrical supply here is not good. Shutting down for a week I even unplug from the wall. Link to comment Share on other sites More sharing options...
[Ra...] Posted December 6, 2021 Author Share Posted December 6, 2021 Power down the air dryer as well I suppose? Power off from switch or do you guys use the software to turn it off ? Link to comment Share on other sites More sharing options...
[Ow...] Posted December 6, 2021 Share Posted December 6, 2021 I never turn the power off to the air dryer. I usually will keep everything on throughout the week and turn the speed control knob on the joystick box to zero before leaving for the day. If I have the portable rotary table set-up, I'll leave it on all week and weekend so I don't have to re-reference it when powering back up. Link to comment Share on other sites More sharing options...
[Me...] Posted December 9, 2021 Share Posted December 9, 2021 CMM every day. Computers on weekends. We have a central dryer for the whole shop. Link to comment Share on other sites More sharing options...
