Graphics problem??
I have a weird problem. We run very high production at our plant. We can have 30 or so different programs running during the day and with three micuras that's a heavy load. We keep a lot of programs open. I know that's not a great idea.
as more programs are opened, the graphics problem increase. Left over lines on the display, missing graphics, and now, the mouse doesn't operate correctly in the graphics window. We can't rotate the view, or pan. This is only in the graphics window. It operates correctly in menus and tabs. I know the high load is to blame ,but is there anything besides restarting the program that can correct this problem ?
Yes, I would suggest you use 'AutoRun' and you will not have graphic problems, but it is a bit painful if you would like to double check the errors etc
Daniel knows what he's talking about. We run high production as well.
We use autorun on all our machines, and It has made life much simpler.
We run many programs at the same time on 3 different machines as well, and we don't use autorun. We had some problems with our graphics and end up downloading the actual graphics drivers for the video cards we have installed. It hasn't fixed it completely, but it sure has helped with performance, so maybe give it try.
