Header Parameters
I want to put the part name in my header. I have activated the header parameter "Part Name" in the Multiple Report window. When I add the text field for the label and the variable but when I use the "Part Name" variable, it outputs the Measurement Plan Name.
Is there a way to search within PiWeb to determine which variable is storing the actual part name value?
I understand I can create a custom user field to handle this but am curious if there is an actual variable.
PiWeb Designer 7.4.13.0
Not really sure why Piweb calls the plan name variable "part name" in the designer. The variable you appear to be looking for is Qdb.Part(1342). Turning on the bubble help option under the ? menu lets you view these next to their tickboxes in the header select menu, at the right hand side. For some reason, the little icons that used to appear there in previous releases don't now.
