Set default/ additional form plot magnifications?
Hi all,
I'm trying to set a default form plot magnification for some profiles of a line I'm running. Currently the dropdown box has "Undefined" and "500" for options. I'd like to add one for 50x. Is there a way to set this as the default?
I don't know of a way to do what you're asking. I assume that somewhere, there is a file holding that info that might be able to be edited. In the meantime, you can go to Resources > Characteristics Setting Editor > PiWeb Reporting and adjust everything to 50x. Click in the list and hit Ctrl-A to select all. Then, enter 50 in the Set To field and hit Enter. Any characteristic that can be plotted will change.
setting plot scale.JPGFetching info...
