O-inspect 543 Drives
We had to power down our O-inspect so a contractor could finish some electrical work.
When I powered it back up the drives would not turn on. Any ideas as to why?
The only problem with drives I frequently had was when one or more of the axes were at or close to their limits. Then the machine would try to home but the axes would hit the limit switches before the controller was ready and the drives went off. I don't know if an active limit switch also prevents drives from turning on, but when in doubt it may be worth a try to pull the axes away from the limits by hand.
