Report Comparison
Is there a way to compare (2) reports and see the deviations of the characteristics? When we "prove out" a new program, we run the part/structure twice for repeatability, then manually compare the .pdf print outs. It's laborious and open to error. I've often wondered if there was a better way? PiWeb perhaps?
If you run the part x number of times, go into Multiple Report and select the Default PiWeb Process from top dropdown menu. Click the Monitor Icon at top to display report.. Then, press F6 or go to Navigation > Show measurement selection and edit the number of measurements to show (equal to number of runs).
If you have a newer version of Calypso, after you display the report, click on the Trend Board button at bottom, then click Measurements tab at top and edit the number of measurements. This report is a bit clearer with more data on each page.
