Planner Axis
I am trying to assist with an issue at our facility and opened our planner seat. For some reason the machine is inverted? When I tried to correct it by running a manual alignment, it said there were issues with Block Edges... 🙄 I changed it over to position points only and tried running the manual alignment again. This allowed me to fix it and corrected the axis issue, no more upside down world. However, the stylus is going THROUGH my work piece. Is there something going on with the Geometry Values for the styli I am using? I assumed when loading the SCC file it would automagically import the geometry, do I need to manually edit these?
What in the name of Oden's raven is going on and how to I fix it?!?
There are two options:
- CAD - Modification - CAD Model Transformation - Transform the model to the correct axis & position
- Plannar - Measurement Plan Simulation - Modify CAD Model (bottom right button) - Transform the model to the correct axis & position
Thanks for the suggestions. I was able to amend the axis inversion, my other query is how to fix the misalignment of the stylus during simulation?
  • 9 months later...
