Freeform Best Fit: Default, Gauss or Tschebyscheff
I programmed a freeform and did a best fit and created a WP alignment. I ran the program in simulation mode, with Active Dispersion turned off. With the default Best Fit there was 0 XYZ Translation and 0 Rotational movement. When I use either Gauss or Tschebyscheff strategies the WP Alignments are shifted significantly.
Shouldn't these strategies produce the same 0 Translation and Rotation in simulation?
  • 2 weeks later...
Dan,
Yes, yes they should. I've experienced the same problem, and I'm currently of the assumption that the problem is a bug in the software. Hopefully it is addressed. I'd love to be corrected otherwise, though.
Jeff Frodermann
Meier Tool & Engineering
Anoka, MInnesota
